UC500 - 7942 Phone Display
Apr 14th, 2010
Quick question regarding the phone display on the 7942.  In the upper right-hand corner the user's name is displayed.  Can this be configured through CLI or does it need to be done via CCA?
Thanks in advance for the help.
Jeff
Steven DiStefano Wed, 04/14/2010 - 06:56
  • Blue, 1500 points or more
I believe you refer to the ephone-dn CLI paramter called "description", which CCA sets for you as the Firstname/lastname as buit in CCA.
jeffrey-young Wed, 04/14/2010 - 07:02
The configuration on the ephone-dn is:
ephone-dn  17  dual-line
number 5584352 no-reg primary
label 4352
description Bryan Gran
name Bryan Gran
call-forward busy 5584362
call-forward noan 5584362 timeout 18
When the 4352 is dialed it displays the name "Bryan Gran" and in the corporate directory it is listed as "Bryan Gran", however; on the physical phone with the 4352 extension it still displays the previous user's name in the upper right-hand corner.
Jeff
Steven DiStefano Wed, 04/14/2010 - 07:05
have you reset the phone after making changes?
Check how it looks in CUE GUI (10.1.10.1) as well...
jeffrey-young Wed, 04/14/2010 - 07:42
It was in fact that I had forgotten to restart the phone.
Thanks again.
Jeff
Steven DiStefano Wed, 04/14/2010 - 07:44
Happens all the time to us too. But CCA does it for us :) <-- shameless CCA Plug :)
jeffrey-young Wed, 04/14/2010 - 07:11
I may have forgotten to reset the phone.  I will do that when I get the all clear from the user.  I only have access to the CLI, I am not on their physical network and do not have vpn access to view the gui.  We'll see if a restart fixes the issue.
I'll let you know.
Thanks again for your time and suggestions.
Jeff
