SFE 2000P configuration lost on power cycle
Apr 14th, 2010
  • Cisco Employee,
I a couple SFE200P switches with the same issue. I set the switch up and have it functioning nicely. All is well. I power switch down overnight and all configuration setting revert back to default settings. This is happening to a few Small Business Switches I have. What am I missing????
I had a similar problem with SFE2000 (after restrat switch doesnot remeber a vlan configuration). My solution was a factory reset and new settings save configuration and this works for me. But I thing You have a other problem try: Admin->file-management->Copy-Files->CopyConfiguration: Running config to startupConfig. This switch not have a "automatic save".
Adam
Darren DeCroock Sat, 04/17/2010 - 07:52
  • Silver, 250 points or more
Adam is correct, the SFE and SGE model switches do not automatically save the running configuration to the startup configuration.  You need to manually go to file managment as Adam listed, and choose to save the running config to the startup config.   If not, when these switches are rebooted, the will load with whatever configuration was last saved in the startup config, which will be the default configuration if you have never saved your current config.
Thank you,
Darren
Related Content
