CUCM 7.1 - Intercoms are very slow to save
Brian Carlson
Level 4
Level 4
I'm using CUCM 7.1.3.20000-2 which is running on a MCS-7845-I3.
When I configure a new intercom for a phone, after I click "save", it takes a very long time to complete the save.  Usually around 30-45 seconds per intercom.  Also, I can't do any other configuration within the CUCM interface while the save is in progress.  Has anyone seen this behavior before?
Thanks!
Rob Huffman
Hi Brian,
It sounds like it might be related to this bug;
CSCsr42175 Bug Details
Intercom Directory Number-Doesn't give "Add Successful" after new add
Symptom:
Intercom Directory Number - It doesn't give "Add Successful" after the new the record has been added. It gives "Status: Ready".
Conditions:
Workaround:
Further Problem Description:
    Status
Open
Severity
4 - minor
Last Modified
Any Time
Product
Cisco Unified Communications Manager (CallManager)
Technology
1st Found-In
6.1(2.9901.55)
7.0(0.39700.169)
7.1(0.39000.86)
Cheers!
Rob
Rob,
It may be related to that bug, but the main issue I am seeing is the amount of time it takes for CUCM to complete the save seems unnecessarily long.  I only notice this delay when configuring intercoms.  I may open a TAC case and register a new bug if this hasn't been seen before.
Rob Huffman
Hey Brian,
I think a TAC case is an excellent idea
I took a long look for anything in any version that looked like your symptoms
and no go.
Cheers!
Rob
