Cisco Security Agent - How can I tell what shims are enabled from MC?
Apr 14th, 2010
For Cisco Security Agent, is there a way I can tell what Shim's are enabled on an agent for a host? Is there a report? Some way from the Console I can tell wothout have to be on the host? Thanks!
Overall Rating: 4 (1 ratings)
jan.nielsen Wed, 04/14/2010 - 17:15
  • Gold, 750 points or more
I don't recall seeing that in the csamc ever, of course an indication would be no logs from any rules that need that specific shim. Also if you do a diagnostic on the host from the csamc you will get a zip file, in this file there could be a file with the registry keys , where you can see what shims are enabled.
