Cisco Aironet LR2 power injector - can't console into it?
Apr 14th, 2010
We have 2 Cisco Aironet Power Injector LR2's (AIR-PWRINJ-BLR2=) and I can't console to either using Cisco sky blue consoel cable.
I am using putty and my setting are:
Speed = 9600
Data Bits = 8
Stop Bits = 1
parity = none
Flow control = none
Leo Laohoo Wed, 04/14/2010 - 15:37
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
I don't believe you can console into a power injector.  Why, if I should ask, are you doing this?
Andy White Wed, 04/14/2010 - 23:04
I was curious that's all. I have a 1301G to connect to it, is it used to configure that?
Leo Laohoo Thu, 04/15/2010 - 15:46
  • Hall of Fame,
    2017 LAN, Wireless
Oh no.
The power injector has only two options:  On or Off.
Andy White Thu, 04/15/2010 - 22:43
How do I configure the 1301 that connects to it via coaxial and why does the LR2 have a console port in the first place?
Leo Laohoo Thu, 04/15/2010 - 23:05
  • Hall of Fame,
    2017 LAN, Wireless
Under Network Management
The power injector does not require configuration or management.
Cisco Aironet 1300 Series Access Point/Bridge Power Injector
http://www.cisco.com/en/US/products/ps5861/products_data_sheet09186a008022551d.html
Leo Laohoo Fri, 04/16/2010 - 04:31
  • Hall of Fame,
    2017 LAN, Wireless
Go to the website posted below.  Choose from either Configuration Examples & TechNotes or Configuration Guides.
http://www.cisco.com/en/US/customer/products/ps5861/tsd_products_support_configure.html
Hope this helps and please don't forget to rate our posts.  Thanks.
haroldlda Sat, 12/17/2011 - 22:39
I spend the same, the AP 1310 is OK, but the power led led off injector LR2. Consoledoes not work
Leo Laohoo Sat, 12/17/2011 - 22:56
  • Hall of Fame,
    2017 LAN, Wireless
Faulty cable to the WAP.
haroldlda Sun, 12/18/2011 - 09:15
Console Cable is ok, but led off power injector. AP LED is ok
Leo Laohoo Sun, 12/18/2011 - 13:35
  • Hall of Fame,
    2017 LAN, Wireless
Console Cable is ok
I'm not talking about the console cable.  The ethernet cable from the injector to the WAP could be faulty.
