CUPS with hosted exchange
Apr 14th, 2010
i am trying to connect CUPS with an hosted exhchange. Is this possible? What is needed to make this work. It is a RPC connection over HTTPS
Aaron Harrison Wed, 04/14/2010 - 08:44
CUPS/CUPC use Exchange in a couple of ways... neither of those is HTTP/RPC.
1) IMAP Access to voicemail from CUPC - obviously requires IMAP access to your mailbox
2) OWA/WebDAV for 'in a meeting' status - requires OWA and WebDAV enabled..
If you don't have these kinds of access, you'll not get access to those features unfortunately. Maybe query your hosting provider on what they will allow...
Please rate helpful posts...
Tommer Catlin Wed, 04/14/2010 - 08:54
You should still be able to use IMAP with a hosted solution to download voicemail..  Meeting free/busy information will not work because of webdav.  I think your bigger issue is, how do voicemails get from (I assume) your onsite Unity or Unity Connection to the hosted solution.  The only way it can is to use SMTP forwarding to the server.  The IMAP will not download the voicemails because they will not be tagged (have not tried, but may work).
If you are using Unity Connection, you could have the CUPC client connect directly the server using IMAP and play voicemails.
Amit Shah Wed, 04/14/2010 - 08:58
As for voice mail, it is on a stand alone unity doing voice mail only (not unified). I am not worried about that. My only concern is trying to get meeting status from exchange
Tommer Catlin Wed, 04/14/2010 - 09:03
Yeah, not going to happen for meeting free/busy information if its hosted.     There is a mentioning of host exchange and Calendaring in CUPS 8.0.  So it may work, but I have not had a chance to test this.
Aaron Harrison Wed, 04/14/2010 - 09:09
So getting WebDAV/OWA access would be one thing... and getting your hosted provider to set up an account with the necessary privileges to access all your users may be another difficult/impossible task.
Related Content
