ACS 4.2 and ATA186
Apr 14th, 2010
Am having trouble with Cisco ATA device when port are configured to use ACS.
When i activate the needed parameter on the port, the ATA device ( voice Vlan ) stop responding to ping.
i need to remove the config and then the device replys to ping but the web interface is still not working, i need to power off the device.
Is there something special to do for port with a ata186 connected to it? any doc?
this is the conf on the port:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
switchport mode access
switchport access vlan 175
authentication event fail action authorize vlan 175
authentication event no-response action authorize vlan 175
authentication port-control auto
authentication periodic
authentication violation protect
authentication timer reauthenticate 3600
dot1x pae authenticator
dot1x timeout quiet-period 5
dot1x timeout server-timeout 15
dot1x max-req 10
dot1x max-reauth-req 10
dot1x timeout auth-period 60
The ATA info:
S/W Version3.02.04(090202A)
H/W Version0x0010 0x0000
Serial NumberINM09061MYC
Product IDATA186I1-A
H/W Features0x00000016
FirmwareATA030204SCCP090202A.zup
VLAN ID100
Config Fileata001360399037
