Capture function in FWSM
Answered Question
Apr 14th, 2010
Hi all,
I am trying to use the capture function in my FWSM on my cat6509.
The function is configured to capture on a certain interface on my firewall context, but I can't seem to capture any traffic (!).
Trying to fix this problem I upgraded to software version 3.2.17 with no luck.
Could you advice please.
Trond
Correct Answer by Giuseppe Larosa about 7 years 2 months ago
Hello Trond,
the FWSM config guide lists some limitations to packet capture feature check if you are hitting one of them:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm32/configuration/guide/troubl_f.html#wp1067860
you can use only an IPv4 ACL and you can only capture IP packets (no ARP or other non IP frames)
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Wed, 04/14/2010 - 11:42
  • Hall of Fame,
    Founding Member
Hello Trond,
Hope to help
Giuseppe
trond.fleitsche... Thu, 04/15/2010 - 05:31
Hi all,
Thanks for your reply.
It seems that the capture functioned after some time. And I learned that it is mandatory to apply an acl to the capture for it to function correctly
Ganesh Hariharan Thu, 04/15/2010 - 00:40
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi all,
Trond
Hi Trond,
Check out the below link for capturing packet in FWSM,Hope to Help !!
http://www.cisco.com/en/US/docs/security/fwsm/fwsm32/configuration/guide/troubl_f.html#wp1068063
Ganesh.H
