WPA2-PSK AES on 1231G
Apr 14th, 2010
I was hoping to get some assistance on getting the 1231g to work with WPA2-PSK (AES).  My laptops cannot authenticate using this config but connect fine to the 1242AG.  Below are some of the specifics:
1231G
Radio Type: AIR-MP31G
IOS Ver: 12.3(8) JED
Multiple SSID
Encryption: AES
Key Management: Mandatory WPA
*Laptops can connect to SSID with WEP
Any help would be greatly appreciated.
Surendra BG Tue, 05/11/2010 - 07:05
  • Cisco Employee,
I am sorry to say this, but in order to do AES with the AP you are using, you MUST have
either an AIR-RM21A or AIR-RM22A...this ap does not have either one of these radios.
...the following excerpt is from the 12.3(2)JA release notes:
AES-CCMP
This feature supports Advanced Encryption Standard-Counter Mode with Cipher Block Chaining
Message Authentication Code Protocol (AES-CCMP). AES-CCMP is required for Wi-Fi Protected
Access 2 (WPA2) and IEEE 802.11i wireless LAN security. This feature is not supported on
350 series access points.
This feature is supported on these devices:
•1100 series access points (802.11g radio only)
•1130AG series access points
•1200 series access points (IEEE 802.11g and 802.11a radios only with the part numbers
AIR-RM21A or AIR-RM22A)
•1230AG series access points (IEEE 802.11g and 802.11a radios only with the part numbers
Surendra
Surendra BG Tue, 05/11/2010 - 07:17
  • Cisco Employee,
Rating the resolution is really appreciated.
Version dependent perhaps? This museum piece supports it
System image file is "flash:/c1200-k9w7-mx.123-8.JEE/c1200-k9w7-mx.123-8.JEE"
cisco AIR-AP1220-IOS-UPGRD (PowerPC405GP) processor with 15138K/1236K bytes of memory.
Product/Model Number                 : AIR-AP1220-IOS-UPGRD
Radio AIR-MP31G, Base Address 0013.c40x.xxxx, BBlock version 0.00, Software version 6.11.8
#encryption mode ciphers ?
  aes-ccm    WPA AES CCMP
  ckip       Cisco Per packet key hashing
  ckip-cmic  Cisco Per packet key hashing and MIC (MMH)
  cmic       Cisco MIC (MMH)
  tkip       WPA Temporal Key encryption
  wep128     128 bit key
  wep40      40 bit key
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
