RME Detailed Device interface Last Changed date reporting
Apr 14th, 2010
How do I create a custom template rule to get ports that have changed since a particular date?
LMS 3.1 RME 4.2
     when creating a custom template rule for "interfaces" "Last Changed", the date format in the rule is different than
     the field in detailed device reports.  I thought the field " last changed " was the point along the sysuptime timeline
     but the sysuptime is less than the number of days in "LastChanged".
any help appreciated..
Michel Hegeraat Thu, 04/15/2010 - 02:32
There is no relation between the sysuptime of a device and the lastchange of any of it's interfaces
john.caterino Thu, 04/15/2010 - 04:52
That explains why the last change numbers are sometimes higher than the sysuptime.  Thank You!!!!
is there a particular way to select the "Value" in RME-Custom Template Reports-Custom Template-rules when choosing
Inventory group= interface ,   Attribute = Last Changed (yy:mm:dd:hh)  ?
The format requires years,months,days and hours while the value of the field is xxxx days, hh:mm:ss
I seem to be unable to get the correct results...
Michel Hegeraat Fri, 04/16/2010 - 11:53
I have never tried that. I always used a selection from the default change report.
Date value are always a pain when queries need to be done. Format probably is US style.
