Avaya Vpn remote IP phone and ASA5510
Apr 14th, 2010
I am looking for some help to configure ASA510 vpn tunnel to work with a Avaya IP Phone.  Has anyone setup this up.
Any assistance would be helpful.
Federico Coto F... Wed, 04/14/2010 - 09:39
  • Green, 3000 points or more
You have a VPN tunnel where the Avaya phone needs to communicate through?
Do you have the call agent on the ASA's local side and the Avaya phone on a remote site?
Is this a L2L or remote access tunnel?
Federico.
keyyo0200 Wed, 04/14/2010 - 09:45
Answer: Tunnel isn't setup yet.
Answer: ASA is at the Corporate office and Avaya phone willbe at a remotes users home.
Answer: remote access tunnel
Federico Coto F... Wed, 04/14/2010 - 09:54
Ok,
So you should start by setting up the remote access VPN tunnel.
Then the phones should be able to register to the call agent.
Remote users should have a broadband internet connection to avoid VoIP traffic latency, jitter, etc.
And you may consider QoS through the VPN tunnel as well.
Federico.
keyyo0200 Wed, 04/14/2010 - 10:00
I am looking for some type of sample configuration to start from with a ASA.
