AAA Authentication Options Configuration
Apr 14th, 2010
The requirement for the router is for the aux and console port to use only local authentication and the VTY lines to use only a TACACS server. I can't seem to find a document that discusses this scenario. Any help would be appreciated.
Panos Kampanakis Wed, 04/14/2010 - 15:58
You can set the default authentication to be local.
And then you can create a custom authentication group to use TACACS and that will be applied under the vty lines.
I hope it helps.
