WIP310 Phone with SwitchVOX 4.5 SMB
Answered Question
Has anyone had any luck connecting a WIP310 phone to a SwitchVox system? We are running SwitchVOX 4.5 SMB. We also have a Linksys PAP2T that connects just fine to the system and using a similar configuration, the WIP310 won't work.
Correct Answer by nseto about 7 years 2 months ago
I haven't used a switchvox but if it's a standard sip proxy, the wip should connect to it.  The settings to use are the same as you configured the pap2t.  Normally just proxy, user ID and pw.  What do you see in the trace or debug log when it tries to register?
Overall Rating: 5 (1 ratings)
Correct Answer
nseto Wed, 04/14/2010 - 16:02
  • Silver, 250 points or more
