4900M - Basic Management Setup - Problem with TACACS+
Answered Question
Apr 14th, 2010
since few weeks I' ve three 4900M switches equipped with the WS-X4920-GB-RJ45 module and the WS-X4908-10GE module. Now I'm started to setup these switches in our lab environment for the first time. They behave a little bit strange in comparison with the C3750 series which I used before and which I will replace by these powerful machines.
I tried to setup these switches to be managed through the management port. I configured IP address, default route in the management vrf, set the source-interface for tftp,ssh,ftp and tacacs to use the management port. Ping using the manangement port was successful. After finishing theses steps I configured the TACACS and AAA settings accordingly the informations I found on CCO. I tested the settings with "test aaa group authentication" command- without success. On my Cisco ACS no request was received and the switch told me he could't reach the tacacs server. Other switches in the same IP subnet are working without failure, so firewall or server should not be the problem. Can anyone give me a hint what could be wrong?
These are parts of the configuration:
enable password test
username test privilege 15 password test
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
ip subnet-zero
ip domain-name test
ip vrf mgmtVrf
vtp mode transparent
crypto key generate rsa general-key modulus 1024
ip ftp source-interface FastEthernet1
ip tftp source-interface FastEthernet1
ip ssh source-interface FastEthernet1
ip vrf forwarding mgmtVrf
ip address 10.119.50.4 255.255.255.0
speed auto
duplex auto
interface Vlan1
no ip address
ip route vrf mgmtVrf 0.0.0.0 0.0.0.0 10.119.50.254
no ip http server
ip http secure-server
ip tacacs source-interface FastEthernet1
tacacs-server host 10.119.32.11
tacacs-server host 10.119.32.12
tacacs-server directed-request
tacacs-server key test
With kind regards
Stefan
Correct Answer by charlesdf22 about 7 years 2 weeks ago
I know I hate getting replies with just links, but do these steps work?
http://nextclickmedia.com/en/US/docs/ios/12_3t/12_3t7/feature/guide/gt_pvt.html#wp1046257
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Wed, 04/14/2010 - 12:41
  • Hall of Fame,
    Founding Member
Hello Stefan,
check if
tacacs-server host command has a vrf option at the end or before inserting the IP address
Hope to help
Giuseppe
bischoff_s Wed, 04/14/2010 - 12:51
Hello Guiseppe,
I checked it before. There is no such option on this command for this switch. In some of the configuration examples that I found from other switches this command was mentioned which in this case was not useful.
Thanks for this hint.
With kind regards
Stefan
bischoff_s Thu, 04/15/2010 - 03:05
Hello Charles,
thank you. Now it is working. It seems that the problem is solved, but now the questions about why it is working arise.
1.) In the Management VRF which is configured by default the RD had to be set. This was not documented under the documentation libray for that device. What effect had this command to the configuration?
2.) For what reason the tacacs-server had to be put in a separate server-group. In my opinion it is only to replace the missing subinterface statement "vrf mgmtVrf" at the end of "ip tacacs source-interface" in the global config.
3.) To document all the settings I changed - this is the actual configuration:
aaa new-model
aaa group server tacacs+ tac_neu
server-private 10.119.32.11 key test
server-private 10.119.32.12 key test
aaa authentication login default group tacacs+ group tac_neu local
aaa authentication enable default group tacacs+ group tac_neu enable
ip subnet-zero
ip domain-name test
ip vrf mgmtVrf
rd 100:1
speed auto
duplex auto
interface Vlan1
no ip address
no ip http server
Thank you for helping me to solve this problem.
With kind regards
Stefan
lewwalker Tue, 01/31/2012 - 08:37
Thanks for the details regarding the management of the Cisco 4900M Switches however I'm attempting to disable the 10/100/1000 MGT port due to security reason. How would I access the port remotely because I have unable to locate this port with the command options.
Related Content
