SA520
KWillacey_2 Wed, 04/14/2010 - 20:30
Yes you may be able to using regular expressions if that proves to be too much of a challenge you can think about investing in the CSC-SSM which is an expansion module for the ASA that filters http (among other things) and offers some flexibility in terms of the file types that can be downloaded.
If you want a more robust solution I would recommend WebSense or IronPort. Hope that helps.
