MDS 9124 error message fc-4 types not registered
Apr 14th, 2010
I have added an IBM AIX host to our SAN and cannot get it to see the NetApp array. I can fcping the host and flogi database looks correct. Zone is configured correctly.  If I run a sh fcns internal reject-log vsan 10 I get the below error but cannot find any documentation as to what it is caused by.  Anyone know what is causing the issue?
VSAN:10    FCID:0x650900
Command                     :NS_CMD_GID_FT
Reject Reason               :unable to perform command
Reject Reason Explanation   :fc-4 types not registered
Time                        :Wed Apr 14 13:57:42 2010
Config info is as follows:
fcsw2com4# sh flogi data
INTERFACE  VSAN    FCID            PORT NAME               NODE NAME
fc1/1      10    0x650200  10:00:00:00:c9:60:16:7b  20:00:00:00:c9:60:16:7b
fc1/2      10    0x650300  10:00:00:00:c9:60:39:2e  20:00:00:00:c9:60:39:2e
fc1/3      10    0x650000  50:0a:09:82:96:d8:25:f0  50:0a:09:80:86:d8:25:f0
fc1/4      10    0x650100  50:0a:09:82:86:d8:25:f0  50:0a:09:80:86:d8:25:f0
fc1/5      10    0x650800  10:00:00:00:c9:4c:7d:46  20:00:00:00:c9:4c:7d:46
fc1/6      10    0x650900  10:00:00:00:c9:66:c0:ab  20:00:00:00:c9:66:c0:ab  <<< this is the new device
fc1/7      10    0x650600  10:00:00:00:c9:7d:34:9c  20:00:00:00:c9:7d:34:9c
fc1/8      10    0x650500  10:00:00:00:c9:7d:39:7e  20:00:00:00:c9:7d:39:7e
Total number of flogi = 8.
fcsw2com4# sh fcalias
fcalias name SRV_p510_ap vsan 10
  pwwn 10:00:00:00:c9:7d:34:9c
fcalias name SRV_p510_db vsan 10
  pwwn 10:00:00:00:c9:7d:39:7e
fcalias name SRV_p550b vsan 10   <<< this is the new device
  pwwn 10:00:00:00:c9:66:c0:ab
fcalias name SRV_vios1 vsan 10
  pwwn 10:00:00:00:c9:60:16:7b
  pwwn 10:00:00:00:c9:60:39:2e
fcalias name STO_lvtlarsa01_1b vsan 10
  pwwn 50:0a:09:82:96:d8:25:f0
fcalias name STO_lvtlarsa02_1b vsan 10
  pwwn 50:0a:09:82:86:d8:25:f0
fcalias name p510_netbackup vsan 10
  pwwn 10:00:00:00:c9:4c:7d:46
fcsw2com4# sh zone
zone name ZNE_vios1 vsan 10
fcsw2com4# sh zoneset
zoneset name PROD_B vsan 10
fcsw2com4# sh zoneset active
  * fcid 0x650000 [pwwn 50:0a:09:82:96:d8:25:f0]
  * fcid 0x650100 [pwwn 50:0a:09:82:86:d8:25:f0]
  * fcid 0x650200 [pwwn 10:00:00:00:c9:60:16:7b]
  * fcid 0x650300 [pwwn 10:00:00:00:c9:60:39:2e]
dguse Wed, 04/14/2010 - 12:48
Also note I am running:
Software
  BIOS:      version 1.0.0
  kickstart: version 3.1(2)
  system:    version 3.1(2)
  BIOS compile time:       10/04/06
  kickstart image file is: bootflash:/m9100-s2ek9-kickstart-mz.3.1.2.bin
  kickstart compile time:  1/18/2007 7:00:00 [02/04/2007 09:27:18]
  system image file is:    bootflash:/m9100-s2ek9-mz.3.1.2.bin
  system compile time:     1/18/2007 7:00:00 [02/04/2007 09:44:36]
Hardware
  cisco MDS 9124 ("1/2/4 Gbps FC/Supervisor-2")
  Motorola, e500 with 515056 kB of memory.
dynamoxxx Thu, 04/15/2010 - 05:06
  • Silver, 250 points or more
is there a reason you have one zone for all of the systems ? It's considered best practice to have either single initiator - single target zoning or single initiator - multiple targets
Once you have zone your AIX box to the NetApp unit, run "cfgmrg". Typically that will force the system login to the array.
Trending Topics: Storage Networking
