ping only success with 1 byte lesser then the mtu i set on ppp multilink interface
Apr 14th, 2010
Hi All,
  i have a stituation which i needed help in explain on this situation.i have 2 routers and i have configure 2 serial links on each router into  a ppp multilink 1, when i ping both ways from both router i need to ping with 1 byte lesser then the mtu size i set. As show below
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:SimSun; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
routerA#ping 202.122.151.129 df si 1604
Sending 5, 1604-byte ICMP Echos to 202.122.151.129, timeout is 2 seconds:
Packet sent with the DF bit set
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/12/12 ms
routerA#ping 202.122.151.129 df si 1605
Sending 5, 1605-byte ICMP Echos to 202.122.151.129, timeout is 2 seconds:
Success rate is 0 percent (0/5)
routerA#sh run int multil 1
Building configuration...
Current configuration : 384 bytes
interface Multilink1
mtu 1605
ip address 202.122.151.130 255.255.255.252
load-interval 30
ppp multilink
ppp multilink group 1
end
routerA#
routerB#ping 202.122.151.130 df si 1604
Sending 5, 1604-byte ICMP Echos to 202.122.151.130, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/10/12 ms
routerB#ping 202.122.151.130 df si 1605
Sending 5, 1605-byte ICMP Echos to 202.122.151.130, timeout is 2 seconds:
routerB#
routerB#
routerB#sh run int multil 1
Current configuration : 380 bytes
mtu 1605
ip address 202.122.151.129 255.255.255.252
load-interval 30
ppp multilink
multilink-group 1
end
Can some one explain to me why i have to ping with 1 byte lesser then mtu i set on?
