04-14-2010 12:55 PM - edited 03-06-2019 10:37 AM
my environment:
WS7609-S <-----> 7204
SUP-720-3B with c7600s72033-adventerprisek9-mz.122-33.SRE1.bin
modules: WS-X6724-SFP , and several GLC-T
now i met these trouble/questions below:
1st: I try to use a twist UTP(straight) connect between 7609's GLC-T 1000M interface and 7200's FastEthernet interface.
But they couldn't go up both line and protocol.
2nd: Now I've to using the GigaEthernet of SUP720 instead of the GLC-T.
That would work well.
Q1: GLC-T can only work in 1000M mode ?
I can't input "speed 100" command in config-if
Solved! Go to Solution.
04-14-2010 01:02 PM
It is not the GLC-T, where it supports 10/100/1000
It is the 6724 line card. Since it is a mix media (SFP) line card, it only supports 1G.
HTH,
jerry
04-14-2010 01:02 PM
HTH,
jerry
04-15-2010 04:08 AM
thank u
