LMS2.6/RME4.0.6/SWIM : upgrade ios failed
Answered Question
Apr 14th, 2010
We have tried to upgrade 3650 :
it works for c3560-ipservices-mz.122-25.SEB4 to c3560-ipservicesk9-tar.122-46.SE.tar see folder 2080.zip
it fails for c3560-ipservices-mz.122-25.SEE2 to c3560-ipservicesk9-tar.122-46.SE.tar see folder 2094.zip
I took a look for bug but I didn't find any.
Thanks, Elisabeth
Correct Answer by Joe Clarke about 7 years 2 months ago
There appears to be a network problem transferring the image to the switch via TFTP.  The operation is timing out.  Check any routers or firewalls along the path to make sure there is nothing that would prevent a large TFTP transfer from completing.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Wed, 04/14/2010 - 23:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
