ESW 520 & 540 PoE capabilities
Apr 14th, 2010
Could you please help me to know the exact number of ports that can be powered at the same time using the PoE capabilities of the ESW-500 family switches?
I mean in the 24 and 48 ports models, the total amount of the ports (24 and 48 ports) can be powered at the same time or the swithces are limited to power only  a specific amount of ports simultaneously  which is less than the total density of the ports ????
Thanks in advance for your support.
Best Regards///Hugo.
