Routing updates
Apr 14th, 2010
I'm facing a issues since couple of months.. I'm running EIGRP in our network and OSPF on MPLS network(connceted to our network), redistributing static routes in both.
the problem is that even though i remove some static routes my network is taking the same old path, routing updates are not happening properly.
Can anyone tell what could be problem??
Tharak Abraham Wed, 04/14/2010 - 21:54
  • Bronze, 100 points or more
Is it a pure MPLS network or MPLS VPN's ?
If you are doing mutual redistribution, please ensure there are no loops !
Please do a traceroute xxxx source yyyy before/after removing the static route and see where your packets are hopping on and on..
Posting some relevant config snippets would be helpful too
kpradeep_venkata Wed, 04/14/2010 - 21:58
it is pure MPLS and we have one IPLC as well. everytime i'm making the link down and up,then everything is working fine
Yasir Ashfaque Thu, 04/15/2010 - 00:32
its probably a looping issue, why dont you draw a sample topology and share with us.
Related Content
