MWI code slow
Answered Question
Apr 14th, 2010
I just finished configuring a CUCM 7.1.3 system.
When I dial the MWI on number from a set, there is a long pause before the MWI
on the phone turns on. Same thing when dialing the off code. On both my 6.1 system and my 3.3
system the lamp on / off is almost immediate. Places to look for the cause of the long pause?
Lee
Correct Answer by rob.huffman about 6 years 9 months ago
Hi Lee,
You'll need to look for an overlapping number in the 51xx range. This sounds like
you are seeing the inter-digit timeout kicking into play here
Cheers!
Rob
Overall Rating: 5 (1 ratings)
Aaron Harrison Thu, 04/15/2010 - 00:42
It might be worth registering a phone to the Publisher and retrying; if it's a replication issue it would then happen much quicker (never came across slow MWI when lighting it from the phone before though)...
Aaron
k6lw Fri, 04/16/2010 - 08:36
I have multiple sets registered with the publisher.
When we dial the MWI activation code 5101 there is
a 15 second delay before the MWI lights. On my
CM3 and CM6 systems the MWI turns on immediately.
Lee
Correct Answer
rob.huffman Fri, 04/16/2010 - 08:46
Hi Lee,
Cheers!
Rob
k6lw Fri, 04/16/2010 - 10:24
Before I saw your response, I did a quick sweep of the system and discovered a CTI route point 5xxxx. Deleted it and all is well. Thanks.
