SSL VPN requirement on ASA 5550 ver 8.2
Apr 15th, 2010
Dear Friends,
There is a requirement to use shared drives through SSL VPN on ASA 8.2 using AnyConnect VPN client
Looking at the AnyConnect Administration guide, i used SBL (Start before Login) feature to configure ASA to use AnyConnect VPN and it is working fine.
I tested it using Windows XP and it was successful.
However, this does not seem to be meeting client requirement as he wants the shared drives to be reachable through VPN without logoff and login (of course after connecting through the VPN first)
This seemed to be possible with F5 but with Cisco ASA, it is possible only by forcing the user to logoff / re-login.
Is there an ability on ASA to contact the AD and run some loginscript to map user's shared network drives like F5?
Thanks a lot
