CSA MC 5.2 restore backup config fails
Apr 15th, 2010
  • Bronze, 100 points or more
Hi, while trying to restore a backup configuration to a CSA MC I get the following error.
Arithmetic overflow error converting expression to data type datetime.
Database csamc52 restoring failed!
From that it looks to be a date formatting error or similar. Any suggestions as to how I can correct or recover from this?
Ross
jan.nielsen Thu, 04/22/2010 - 06:56
  • Gold, 750 points or more
Is it a restore to the same server as the backup was created on ?
rmcarthur Thu, 04/22/2010 - 07:13
Hi Jan, thanks for responding. Yes, this is an attempt to restore to the same MC the backup was created from.
Ross
jan.nielsen Thu, 04/22/2010 - 12:06
So just to be sure :
The server newly installed and is up and running with a default config, or are you just trying to revert a working csamc to an older backup ?
Are you local admin on the server ?
Did you remember to stop the csagent on the server before running restore ?
Are you running the same csamc version on the server as when the backup was done ?
Jan
rmcarthur Fri, 04/23/2010 - 01:22
Hi Jan, the server is more or less new though I have generated quite a few rules.
The MC is fully operational and has no problems, I just wanted to test and verify the operation of the restore process before I really need to use it. I'm glad I did!
I have local admin privileges on the server the MC is installed on.
I am attempting to use the restore configuration utility in the /bin directory which performs the agent stop operation as part of its process.
I am restoring to the same MC that the backup was made from.
If you need any further information, just ask
Thanks again for your help.
Ross
jan.nielsen Tue, 04/27/2010 - 14:34
I'm fresh out of ideas, you should probably start a TAC case for this issue.
rmcarthur Thu, 04/29/2010 - 03:07
Hi Jan, thanks for your time and I appreciate your help with this problem.
There are other issues with the install now too so I agree that the next step is a TAC case.
Thanks again,
Ross
