04-15-2010 03:08 AM - edited 03-11-2019 10:33 AM
04-15-2010 03:17 AM
Doesn't look correct.
Can you please advise what is the ip address of the outside interface, and the ip address of the DMZ server?
04-15-2010 04:08 AM
I will give made up IP
Remote IP: 22.22.22.22
My outside IP: 11.11.11.11
My DMZ Server: 33.33.33.33
04-15-2010 05:07 AM
OK, base on the following information:
You can configure the following:
static (DMZ,Outside) tcp interface 1200 33.33.33.33 1200 netmask 255.255.255.255
access-list Outside_access_in permit tcp host 22.22.22.22 host 11.11.11.11 eq 1200
I assume you already have the following:
access-group Outside_access_in in interface outside
OR/ alternatively if you need to be very specific that only traffic from 22.22.22.22 needs to be translated, then the following:
access-list DMZ-NAT permit tcp host 33.33.33.33 eq 1200 host 22.22.22.22 eq 1200
static (DMZ,Outside) tcp interface 1200 access-list DMZ-NAT
04-15-2010 05:17 AM
Thanks, I will give that a bash
I have sent you a PM. Can you have a look please?
