Recording with CCX8.0
Apr 15th, 2010
Good morning everyone! I would like to know if anyone could explain me wath is "compliance recording" in CCX8.0? this mean that i can have full record of all the calls even with Enhanced agents? or do i need Quality Manager and Premium agents? because i was reading in the "Cisco Unified Contact Center Express Solution Reference Network Design" and it says that "complaince recording" is available for Enhance Standard and Premium agents, and Quality manager is only available for Premium agents, so i didnt understood what do i need to have for having full recording of my calls! Thanks and best regards!! João Mendes
Overall Rating: 4 (1 ratings)
Aaron Harrison Thu, 04/15/2010 - 03:45
  • Community Spotlight Award,
    Member's Choice, May 2015
Quality Manager is a separate product, but it's licensing is controlled through UCCX in later versions. It basically does call recording (for quality management, i.e. scoring purposes) and has an option to do 'archive recording' (long term recording of calls). If you get Advanced QM then you also get screen recording.
Compliance Recording is just the 'archive' recording component of QM...
So:
Compliance Recording = audio archiving/recording
QM = adds scoring etc to the archiving
AQM = add video
They are all the same product, which runs on Windows on a separate server.
Aaron
Please rate helpful posts..
jpdmendes Thu, 04/15/2010 - 04:11
Hi Aaron!
First off all thanks for your answer!! just to see if I fully understand, I need to have all the time Quality manager for having call recording isn't? thank you very much!
Aaron Harrison Thu, 04/15/2010 - 04:14
If you have just UCCX, you get the standard recording features - 7-day retention period, and only ad-hoc recording.
Compliance Recording is basic version of Quality Manager, which you would need if you want full recording of all agent calls and long retention periods.
Aaron
jpdmendes Thu, 04/15/2010 - 04:18
That's exactly what i need, full recording of all agent calls and long retention periods, so i just need Compliance Recording correct? do you know how can I configure the compliance recording? thanks again Aaron!!
Aaron Harrison Thu, 04/15/2010 - 04:21
First thing is - you need to purchase it. It's a licensed feature, so you need to buy it.
Unlike UCCX, you install it on a standard version of Windows 2003 and SQL (which you would also need to purchase yourself).
The installation guides for QM are here:
http://www.cisco.com/en/US/products/ps8293/prod_installation_guides_list...
Aaron
Please rate helpful posts...
scarlos14 Tue, 03/01/2011 - 13:38
Hi Aaron,
I have a question regarding to your discussions.
I am trying to setup a AQM 8.5 solution but I get confused by the part numbers.
If the QM and AQM have features of 100% call recondings why there are different types o PNs like these below:
CR only
QM only
AQM only
CR QM and AQM
I have got these options in the UCS Sizing Tool for Call Centers.
The design guide says that I can have a mix of CR, QM and AQM.
Thanks in advance,
Silvio
