EIGRP problem. I can´t install a static route into eigrp topology table
Apr 15th, 2010
Hi all,
I have a problem to insert into EIGRP a per-user static route via RADIUS.
When RADIUS send av-pair to router the router install routes into routing table but, and this is my problem, EIGRP dont install into topology table only in certain case.
I can see that.
sh ip route static
U [1/0] via
U [1/0] via
both routes are assigned via user in RADIUS
userpp        Auth-Type := local, User-Password == "pass"
                Framed-IP-Address =,
                cisco-avpair += "ip:route#1=",
                cisco-avpair += "ip:route#2=",
                Service-Type = Framed-User,
                Framed-Protocol = PPP
but only the route that his nexthop is different to the user IP works.
sh ip eigrp topolo
IP-EIGRP (AS 10): Topology entry for
  State is Passive, Query origin flag is 1, 1 Successor(s), FD is 2816
  Routing Descriptor Blocks:, from Rstatic, Send flag is 0x0
      Composite metric is (2816/0), Route is External
      Vector metric:
        Minimum bandwidth is 1000000 Kbit
        Total delay is 10 microseconds
        Reliability is 255/255
        Load is 15/255
        Minimum MTU is 1500
        Hop count is 0
      External data:
        Originating router is (this system)
        AS number of route is 0
        External protocol is Static, external metric is 0
        Administrator tag is 0 (0x00000000)
sh ip eigrp topology
% IP-EIGRP (AS 10): Route not in topology table
I am using IOS c7200-adventerprisek9-mz.124-24.T1.bin
But the same configuration (at least I think that) works well for both routes in other router
Somebody can help me?
thanks in advance.
El mensaje fue editado por: david.knet
Overall Rating: 5 (1 ratings)
david.knet Mon, 04/19/2010 - 02:58
I found the solution.
I don´t know why but in this case EIGRP can't take the metric for static routes automatically. So as, i set into redistribution route the set metric command and the route start to appear into EIGRP topology table.
Somebody know some debug where i could see this behavior?
Giuseppe Larosa Mon, 04/19/2010 - 03:07
Hello David,
now that I see it, it is a reasonable solution and you have been kind to provide feedback
about debug commands
may be the FSM debug may be of help
debug ip eigrp ?
  <1-65535>      AS number
  <1-65535>      Autonomous System
  neighbor       IP-EIGRP neighbor debugging
  notifications  IP-EIGRP event notifications
  summary        IP-EIGRP summary route processing
  vrf            Select a VPN Routing/Forwarding instance
debug eigrp ?
  fsm        EIGRP Dual Finite State Machine events/actions
  neighbors  EIGRP neighbors
  nsf        EIGRP Non-Stop Forwarding events/actions
  packets    EIGRP packets
  transmit   EIGRP transmission events
note that there are two series of debug commands one with ip keyword and one without
Hope to help
david.knet Mon, 04/19/2010 - 03:34
Thank you Giuseppe,
I will try "debug eigrp fsm". I am sure that DUAL is the responsable for that.
I did try different debugs, including some "debug eigrp" but for some reason i didn't view fsm...
