BGP question
Apr 15th, 2010
guys suppose we are having 10 or 20 routes on WAN router learned from EIGRP
the wan routers has 10.15.15.0/24 to 10.15.X.0/24 etc (learned from EIGRP) and if we want to advertise a router in BGP can we use
10.15.0.0/16 route rather then putting 20 routes secondly do we have to put static null route for 10.15.0.0/16 or not
thanks for looking
lamav Thu, 04/15/2010 - 07:19
  • Blue, 1500 points or more
You can advertise that /16, yes. You can also suppress the advertisement of the specific prefixes.
ip route 10.15.0.0 255.255.0.0 null0
router bgp 1
aggregate-address 10.15.0.0 255.255.0.0 summary-only
Victor
comsats Thu, 04/15/2010 - 07:27
Thanks for the answer now i have a question do we really have to advertise the null0 route......if eigrp connection breaks
up even then the routes would be advertised in BGP ??? am i right or wrong secondly my main question remains stands
if we dont do null0 routes would this work or not??? thanks again
Collin Clark Thu, 04/15/2010 - 07:40
  • Purple, 4500 points or more
In order to advertise a route into BGP, the local router must have that route in its local routing table. The null0 route is not advertising, it's putting the /16 route into the local routing table so BGP can advertise it.
Collin Clark Thu, 04/15/2010 - 07:50
Is it possible for you to summarize the routes before your MPLS router? Then your MPLS router will already have the /16 route in its routing table and you don't have to worry about creating any to null0.
Giuseppe Larosa Thu, 04/15/2010 - 08:05
  • Hall of Fame,
    Founding Member
Hello Comsat,
the route to null0 is not strictly required you can use
network command for each component route
+ aggregate-address for the aggregate if you want to create the aggregate
usually the static to null0 is combined with a network command that matches directly the aggregate
Hope to help
Giuseppe
comsats Thu, 04/15/2010 - 09:02
Thanks guys for your help now one more and final question.......actually there are two wan routers (the quetion is not abt the second one)
i am advertising  three networks in BGP 10.4.1.0/24
10.5.1.0/24
10.6.1.0/24
the aggregation will be look like this (correct me if i am wrong)
aggregate-address 10.4.0.0 255.255.0.0 summary-only
aggregate-address 10.5.0.0 255.255.0.0 summary-only
aggregate-address 10.6.0.0 255.255.0.0 summary-only
is it correct ?
and if i want to prepend 10.6.1.0/24 (this the requirment)
so all i have to create a prefix-list and it should look like this
ip prefix-list prepend_network_to_isp seq 10 permit 10.6.0.0/16 (it shd be /16 not 24 right????)
route-map my_prepend permit 10
match ip address prefix-list prepend_network_to_isp
set as-path prepend X.X.X
now the imp question is shd i add permit staement in the route map (like same route _map for two other as i have read that then those two will be denied)
if yes how it shd look like
guys thanks again for looking
Jon Marshall Thu, 04/15/2010 - 09:17
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
10.5.1.0/24
10.6.1.0/24
As Giuseppe pointed out with the aggregate-address command you don't need a matching route in the routing table you just need at least one of the subnets of the aggregated address.
As for the above if you have 3 /24 networks why do you want to advertise them as 3 /16 summary addresses. I mean you can but is this really what you want to do eg.
10.4.0.0/16 as a summary address would be 10.4.1.0 -> 10.4.255.0, do you really want to do that ?
Jon
comsats Thu, 04/15/2010 - 09:48
Jon you are right the main thing is which i cant get my head around is that i have around
70 networks 10.4.1.0 to 10.4.200.0/24 its mix actually now i am advertising in bgp
router bgp 1
neigbour X.X.X.C remote_as X route-map traffic_out out
network 10.4.1.0 mask 255.255.255.0 (its 24 not 16)
and then
ip prefix-list WAN_list seq 10 permit 10.4.0.0/16
route-map traffic_out permit 10
match ip address prefix-list WAN_list
This is the best i could think of
now my question is will it advertise all my 70 networks
Yes or no???
now shd i use null0 or not??? as i am getting all teh routes from IGP (all /24)
kindly guide me guys
Jon Marshall Thu, 04/15/2010 - 09:55
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
router bgp 1
and then
Yes or no???
It won't advertise all 70 routes, it will advertise a summary route of 10.4.0.0/16 to EBGP peers.
Also because you are using the summary-only keyword i'm not sure what the route-map is meant to achieve because all the more specific 10.4.x.0/24 networks will not be advertised anyway.
You do not need to use Null0.
Jon
comsats Thu, 04/15/2010 - 10:17
JON
       so if /16 would be summarized still ppl can reach 70 networks that what i meant to ask......as i cant add 70 network commands in BGP
what is the solution am i doing wrong or what???
task is 70 routes with 10.4.X.X /24
so i have add 10.4.1.0/24 (which is the first subnet) and then aggregating them with /16
the route-map is cuz i am using 10.4.1.0/24 in network statement under BGP so i thought to use 10.4.0.0/16 in route-map tied up with prefix-list
look i am here as i m having problem and i m unsure
what do u think
and thanks again
Jon Marshall Thu, 04/15/2010 - 10:22
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
comsats wrote:
JON
what do u think
and thanks again
The "summary-only" keyword you are using with your aggregate address stops any individual subnets that makes up the summary address being advertised so only 10.4.0.0/16 will be advertised.
Yes, people should be able to reach all 70 networks because the summary address covers all those 70 networks but be aware it also covers a lot more than just 70 /24 networks.
Jon
comsats Thu, 04/15/2010 - 10:27
Thanks JON 100 out of 100 (you deserve that) :-)
so am i doing the right thing putting 10.4.1.0/24 under BGP and doing aggregation with /16
r u happy with route-map???? does it make sence now???
Jon Marshall Thu, 04/15/2010 - 10:28
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
I still don't think you need the route-map because your router will only advertise out the /16 summary address. However it's not doing any harm.
Jon
comsats Thu, 04/15/2010 - 23:51
Jon
     Now one last question buddy and i guess it takes me to square one........i hav ethose 10.4.1.0/24 to 200 (its mix) so all togather 70 routes on my WAN router.......we have dual home BGP connection with one AS though........no IBGP is running and dont ask me why :-) as it was before i joined.....
now i have another 40 routes in WAN router (from EIGRP) which i dont want to advertise and excpet one which is 10.5.1.0/24 (there are 10 of them)
the requirment is that 10.4.1.0/24 till 10.4.200.0/24 takes ISP one and 10.5.1.0/24 to 10.5.200.0/24 takes ISP 2 as primary.
now as discussed earlier what shd be my config
under bgp 1
neigbour X.X.X.X remote-as 2 route map WAN_out out
network 10.4.0.0 mask 255.255.255.0
network 10.5.0.0 mask 255.255.255.0
Now shd i use network 10.4.1.0 massk 255.255.255.0 or the one which is above is right
or shd i just redistribute EIGRP into BGP with no network statement (Man i am confused)
now two things i have to do prepend for 10.5.0.0 network and advertise only these two supernets as i have other networks which i dont want to advertised in BGP
so ip prefix-list shd be
ip prefix-list Filter seq 20 permit 10.4.0.0/16
ip prefix-list Filter seq 21 permit 10.5.0.0/16
route-map WAN_out out permit 10
match ip address prefix-list Filter
now how i will do prepend for 10.5.0.0/16 network on this router
Jon Thanks again Dude
ozzyosbu1 Fri, 04/16/2010 - 00:42
hello experts
just one doubt, for the aggregate to be announced at least one specific network should be there in the bgp table.
now as per the configuration, only one specific /24 will be there in the bgp table and if that specific goes down there wont be any more specifics in the BGP table( it will still be there on the routing table though( through IGP)). so this would mean that the aggregate will not be advertised. And no reachabilty from out side to any of the networks..!
Giuseppe Larosa Thu, 04/15/2010 - 09:16
  • Hall of Fame,
    Founding Member
Hello Comsats,
at list one component router per aggregate-address has to be in the BGP table
the prefix-list should match the prefix you want to be prepended
ip prefix-list tobeprepended permit 10.6.0.0/16
you need a second empty route-map block or you will send out only one prefix
You should prepend only your own AS number one or more time.
Hope to help
Giuseppe
