UC520 not allowing another call to conference call
Answered Question
Apr 15th, 2010
UC520 is not letting another caller to be added to an existing conference call, when I try to add another person and hit conference it disconnects one of the callers from ongoing conference call. I have a 64 channel DSP installed.
thanks
hasrat
Correct Answer by Rob Huffman about 6 years 10 months ago
Hi Hasrat,
The octo-line config won't come into play here
This config setting;
max-conferences 8 gain -6
relates to the number of simultaneous Conferences not the number of
participants;
look for;
max-conference participants
Have a look at this excellent doc from Tony @ Cisco;
https://www.myciscocommunity.com/docs/DOC-1486
Cheers!
Rob
Overall Rating: 5 (2 ratings)
Hasrat Raja Thu, 04/15/2010 - 07:55
Hi Rob,
Thank you for the reply, do I need to add octo-line to ephone-dn, right now they are configured as dual-line ?
this is what I see under telephony-service regarding conference:
sdspfarm tag 1 conference
hasrat
Correct Answer
Rob Huffman Thu, 04/15/2010 - 08:27
Hi Hasrat,
participants;
look for;
Cheers!
Rob
Hasrat Raja Thu, 04/15/2010 - 09:00
Hi Rob,
excellent document, followed it and I am seeing this:
uc520(config-dspfarm-profile)#maximum sessions ?
  <1-2>  Number of sessions assigned to this profile
it is not allowing me to add more than 2 sessions.
thanks
hasrat
Hasrat Raja Thu, 04/15/2010 - 14:08
Hi Rob,
I did not apply ephone-dn for ad-hoc, once I added them it is working.
thanks for the document.
hasrat
Rob Huffman Thu, 04/15/2010 - 09:12
Hi Hasrat,
Don't forget that each DSP is related to a Conf profile as shown below. Your profile must be set up in mixed mode. Your original question referenced the number of participants not the number of sessions:)
voice-card X Replace X with slot number where the DSPs reside
dsp services dspfarm Enable dspfarm services
sccp local FastEthernet0/0 Specify local SCCP interface
sccp ccm 192.168.10.1 identifier 100 version 4.0 Configure IP address of call-agent to register sccp/use version 4.0
sccp Enable SCCP
sccp ccm group 1 Define SCCP group
associate ccm 100 priority 1 Associate sccp identifier with ccm group
associate profile 1 register confprof1 Configure sccp profile name
voice class custom-cptone jointone Optional – configure join tone
dualtone conference
frequency 600 900
cadence 300 150 300 100 300 50
voice class custom-cptone leavetone Optional – configure leave tone
dualtone conference
frequency 400 800
cadence 400 50 200 50 200 50
dspfarm profile 1 conference Configure dspfarm conference parameters
codec g711ulaw Configure codecs that are allowed to participate – by default all codecs are supported
codec g729r8 Configure codecs that are allowed to participate – by default all codecs are supported
conference-join custom-cptone jointone Specify jointone - optional
conference-leave custom-cptone leavetone Specify leavetone - optional
maximum conference-participants 8 Configure max conference participants per conference
maximum sessions 8 Configure maximum number of conferences
associate application SCCP Activate SCCP application
no shut Enable dspfarm profile
Each DSP can support a maximum of 16 G.711/G.729A/G.729 participants (mixed-mode), so this translates to:
• 2 conferences of 8 participants each
Cheers!
Rob
Hasrat Raja Thu, 04/15/2010 - 10:31
Hi Rob,
This is the config related to conference, it is still not working:
voice-card 0
dspfarm
sccp local Vlan10
sccp ccm 172.18.1.30 identifier 1 version 6.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
codec g711ulaw
maximum sessions 8
telephony-service
sdspfarm units 1
sdspfarm tag 1 confprof1
conference hardware
thanks
hasrat
Rob Huffman Thu, 04/15/2010 - 07:39
Hi Hasrat,
A 3-party Conference is the default on the uc520
UC 500 DSP: Conference and Transcoding Capabilities/Limitations
https://supportforums.cisco.com/docs/DOC-9744
Software Conference: Default conference option for UC500. Software conferencing enables 3-party ad-hoc conferencing capabilities and is enabled by default for a maximum of 8 conferences (8x3).
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
