WAAS in a hybrid configuration (WCCP and inline modes)
Apr 15th, 2010
Is it possible to configure WAAS solution in a hybrid configuration, with the central office working in wccp mode and the remote offices in inline mode?
If it is possible, will I have some impact in the solution performance?
Best Regards.
Zach Seils Wed, 04/21/2010 - 09:10
Hi Fujimura,
The network integration/interception method you choose is site specific.  It is perfectly fine to use WCCP at some sites and Inline at others.  The WAAS devices are not aware what the peer WAAS devices on the other side of the WAN are using for interception.
Related Content
