Nexus 7K CMP port
Apr 15th, 2010
Has anyone seen an issue where the N7K CMP port only works at a gig?  I'm trying to connect a CMP port to a 3550 being used as a out of band mangement switch.  I can't find a way to change the port speed on the CMP.  It only seems to work if I use a cross over cable to my gig port on my laptop.
kitanaka Fri, 05/14/2010 - 10:35
Have you tried reloading cmp ? There is no speed command supported on cmp port.
I'm seeing an issue (link is up but no reachability) when I change speed setting on the connected switch to 100M or 10M which can recover
by reloading cmp. It is under investigation but you might take this workaround since changing speed on the connected port is not a daily thing, I suppose.
Best regards,
