2 gateways of last resort
Answered Question
What will happend if two gateways of last resort is configured on a 6509?
ip route 0.0.0.0 0.0.0.0 172.16.24.1
ip route 0.0.0.0 0.0.0.0 172.31.14.254
Will the 6509 going to pick 172.16.24.1 or is it going to load balance between the 2 ?
TIA
Overall Rating: 5 (1 ratings)
Faizan Shaikh Thu, 04/15/2010 - 11:36
Jon,
Is it going to play round-robin for these two static routes?
If yes, how does it actually happen?
is it session based or something?
Faizan
Jon Marshall Thu, 04/15/2010 - 11:40
fisi1232000 wrote:
Jon,
Faizan
Faizan
Yes it will and it does it based on destination address.
Jon
Jon Marshall Thu, 04/15/2010 - 12:03
fisi1232000 wrote:
Jon,
"based on destination address"
Can you please elaborate this in brief ?
There are 2 types of load-balancing , per-packet and per-destination.
Per-packet means each packet is routed separately so with 2 default routes each new packet would be sent over alternate default routes.
Per-destination means each packet that is going to the same destination is sent over the same path using the same default route.
Have a look at this doc for more details -
http://www.cisco.com/en/US/customer/tech/tk365/technologies_tech_note09186a0080094820.shtml#perper
Edit - should have mentioned that on a 6500 with sup720 only per-destination load-balancing is supported.
Jon
Faizan Shaikh Thu, 04/15/2010 - 12:12
Jon,
Okay, good.
It means for 'per packet', same packet will go through two default routes.
and 'per destination' means one packet one destination.
Faizan
Jon Marshall Thu, 04/15/2010 - 12:23
fisi1232000 wrote:
Jon,
Okay, good.
Faizan
Faizan
The same packet cannot go through 2 default routes. per-packet means packet 1  is sent over default-route1, packet 2 is sent over default-route2, packet 3 is sent over default-route1, packet 4 is sent over default-route2 etc....
per destination means any packet with the same destination IP address in the IP header is sent over the same default-route.
Jon
