AP Installation Guidelines
Answered Question
Apr 15th, 2010
Hi Guys,
Good day!
I will be installing a 2x Wireless AP (1242-AG) in 60m square room, I will install it in both ends of the room. My question is what are the guidelines that I will be considering in situation like this, e.g. channels to be used, % overlaps (to avoid disconnection when user pass to other access point), antennae... etc.
Thanks in advance!
regards,
Gagamboy
Correct Answer by Leo Laohoo about 6 years 11 months ago
do you mean I do not need to manualy adjust the channel of Wireless AP?
You should be able to get things working without making any adjustment to the channel assignments.
Overall Rating: 5 (1 ratings)
Leo Laohoo Thu, 04/15/2010 - 15:28
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
  Why?  Do you want wireless coverage OUTSIDE the room too?
channels to be used
You should be fine.  You have two APs so they'll automatically sort themselves out.
gagamboy15 Thu, 04/15/2010 - 20:17
Hi Leo,
Thanks for your feedback.
It will only serve inside the room, no need for outside. :-)
As for the channels, do you mean I do not need to manualy adjust the channel of Wireless AP?
Thanks in advance!
regards,
Mark
Correct Answer
Leo Laohoo Thu, 04/15/2010 - 20:41
  • Hall of Fame,
    2017 LAN, Wireless
Leo Laohoo Thu, 04/15/2010 - 21:02
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the ratings.
