04-15-2010 09:56 AM - edited 03-06-2019 10:38 AM
In our org we are 3560 switches as layer 2 swtiches only workstations are connected to it , since i am new here i am seeing mls qos commands and srr-queue commands just wanted to know do we need really need bandwidth share QoS enabled when i switch is acting as a layer 2 switch..
Karthik
04-15-2010 10:07 AM
Hi Karthik,
If you don't need QOS, then don't configure it specially since you are not running VoIP.
Reza
04-15-2010 10:14 AM
karthikgopi wrote:
Karthik
Karthik
Impossible to say without knowing the company policy on bandwidth usage, security etc. They may be there for a very good reason and then again they may be just default config. Just because the 3560 is acting as a L2 switch does not mean the QOS commands are not being used.
Jon
04-15-2010 11:24 AM
I agree with Jon here, whether you have VoIP or not does not necessarily mean that you don't require QoS. QoS maybe implemented specifically for egress scheduling for other protocols other than Voice. Therefore QoS may have simply been configured due to your own company policy/requirements or has been configured without any specific reason. Unfortunately you will only be able identify the real reason from discussing this with your peers.
Allan.
