blocking phone numbers
cooperben
3825 with 12.4.24T AdvIPServices IOS with 2 PRI's.  Internal 4-digit extensions are from 3600-3899.
I've configured the 3825 in order to set up call blocking so that from now on, we only need to add new rules to the voice translation rule.  However, when I test using my cell phone number, it does not get rejected.  Did I miss something?  I have shut/no shut the PRI ports already.  Relevant config below.  Thanks in advance.
voice translation-rule 77
rule 1 reject /5045551212/
voice translation-profile call-blocking
translate calling 77
voice-port 0/0/0:23
translation-profile incoming call-blocking
timeouts interdigit 3
voice-port 0/0/1:23
dial-peer voice 10 voip
call-block translation-profile incoming call-blocking
call-block disconnect-cause incoming call-reject
destination-pattern 36..
session target ipv4:x.x.x.x
incoming called-number .
dtmf-relay h245-alphanumeric
dial-peer voice 20 voip
destination-pattern 37..
dial-peer voice 30 voip
destination-pattern 38..
William Bell
Well, actually you need to make a few adjustments here:
1. remove the translation profiles under the voice ports
voice-port 0/0/0:23
no translation-profile incoming call-blocking
voice-port 0/0/1:23
2. Remove the call-block under the voip dial-peers
no call-block translation-profile incoming call-blocking
no call-block disconnect-cause incoming call-reject
3. Add new pots dial-peers
dial-peer voice 1 pots
direct-inward-dial
dial-peer voice 100 pots
incoming called-number 3[6-8]..
direct-inward-dial
hth.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
