Router on a Stick Configuration
jdleon
If a network is subnetted, like for example 192.168.1.0/24 is subnetted to 192.168.1.0/25 & 192.168.1.128/25, can a router on a stick configuration be used?
5 Replies 5
Jon Marshall
Yes it can eg.
vlan 10 = 192.168.1.0/25
vlan 11 = 192.168.1.128/25
switch config
int fa0/1
switchport mode trunk
switchport trunk allowed vlan 10,11
router config
int fa0/0.10
encapsulation dot1q 10
ip address 192.168.1.1 255.255.255.128
int fa0/0.11
encapsulation dot1q 11
ip address 192.168.1.129 255.255.255.128
Jon
I will try this config.  I appreciate your help.
Thank you
bmbreer1000
Without VLANs you would simply apply an IP address from 192.168.1.0/25 to the router interface and a secondary IP address from 192.168.1.128/25 to the same router interface.
I will try this second solution also.  I appreciate your help.
Thank you.
No problem, glad to have helped.
Just be aware if you use secondary addressing then you must have all the clients in the same vlan on the switch(es) ie. you are no longer routing between vlans.
Jon
