Need Clarification: Do I Need An IOS Upgrade?
XXX_OPS#show ver
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(15)T12, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 22-Jan-10 02:04 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
ABT_OPS uptime is 2 days, 58 minutes
System restarted at 15:11:28 PCTime Tue Apr 13 2010
System image file is "flash:c2800nm-ipbase-mz.124-15.T12.bin"
Cisco 2821 (revision 53.51) with 514048K/10240K bytes of memory.
Processor board ID FTX1413AJTF
2 Gigabit Ethernet interfaces
1 Serial interface
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
126976K bytes of ATA CompactFlash (Read/Write)
ABT_OPS#
I want to do dot1q tagging and vlan trunking on this router.  Is it possible?
Jon Marshall Thu, 04/15/2010 - 13:22
Frank
According to Feature Navigator IP Base on the 2800 ISR routers should support 802.1q trunking so you should be fine. If you want to make sure then try this -
int gi0/1.10
encapsulation dot1q 10
ip address x.x.x.x
if you can enter the above config you are good to go.
Feature Navigator is the tool to use for these sort of queries -
Feature Navigator
Jon
vmiller Thu, 04/15/2010 - 13:29
here is the screen shot from feature navigator
Software Select One IOSCatOS
Major ReleaseSelect One --- IOS --- 15.1XB 15.0M 12.4XW 12.4XT 12.4XJ 12.4XE 12.4XC 12.4XA 12.4T 12.4 12.3ZA 12.3YZ 12.3XL 12.3T
ReleaseAll Releases --- IOS --- 12.4(25c) 12.4(25b) 12.4(25a) 12.4(25) 12.4(23a) 12.4(23) 12.4(21a) 12.4(21) 12.4(19b) 12.4(19a) 12.4(19) 12.4(18b) 12.4(18a) 12.4(18) 12.4(17b) 12.4(17a) 12.4(17) 12.4(16b) 12.4(16a) 12.4(16) 12.4(13e) 12.4(13d) 12.4(13b) 12.4(13a) 12.4(13) 12.4(12c) 12.4(12b) 12.4(12a) 12.4(12) 12.4(10c) 12.4(10b) 12.4(10a) 12.4(10) 12.4(8d) 12.4(8c) 12.4(8b) 12.4(8a) 12.4(8) 12.4(7h) 12.4(7g) 12.4(7f) 12.4(7e) 12.4(7d) 12.4(7c) 12.4(7b) 12.4(7a) 12.4(7) 12.4(5c) 12.4(5b) 12.4(5a) 12.4(5) 12.4(3j) 12.4(3i) 12.4(3h) 12.4(3g) 12.4(3f) 12.4(3e) 12.4(3c) 12.4(3b) 12.4(3a) 12.4(3) 12.4(1c) 12.4(1b) 12.4(1)
PlatformAll Platforms --- IOS --- 1701 1711 1712 1721 1751-V 1760 1841 2610XM-2611XM 2620XM-2621XM 2650XM-2651XM 2691 2801 2811 2821 2851 3220 3250 3631 3640 3640A 3660 3725 3745 3825 3845
Feature Set/License(s)All Feature Sets/Licenses ADVANCED ENTERPRISE SERVICES ADVANCED ENTERPRISE SERVICES WITH SNA SWITCHING ADVANCED IP SERVICES ADVANCED SECURITY AISK9-AESK9 FEAT SET FACTORY UPG FOR BUNDLES AISK9-AISK9 FEAT SET FACTORY UPG FOR BUNDLES ASK9-AESK9 FEAT SET FACTORY UPG FOR BUNDLES ASK9-AISK9 FEAT SET FACTORY UPG FOR BUNDLES ASK9-ASK9 FEAT SET FACTORY UPG FOR BUNDLES ENTERPRISE BASE ENTERPRISE BASE W/O CRYPTO ENTERPRISE SERVICES ENTERPRISE SERVICES W/O CRYPTO INT VOICE/VIDEO GK, IPIP GW, TDMIP GW INT VOICE/VIDEO GK, IPIPGW, TDMIP GW AES INT VOICE/VIDEO, IPIP GW, TDMIP GW INT VOICE/VIDEO, IPIPGW, TDMIP GW AES IP BASE IP BASE W/O CRYPTO IP VOICE IP VOICE W/O CRYPTO SP SERVICES SPSK9-AESK9 FEAT SET FACTORY UPG FOR BUNDLES SPSK9-AISK9 FEAT SET FACTORY UPG FOR BUNDLES SPSK9-ESK9 FEAT SET FACTORY UPG FOR BUNDLES SPSK9-SPSK9 FEAT SET FACTORY UPG FOR BUNDLES
New Search
Search Results
Cisco IOS quick pick latest Releases
GD Release
LD Release12.4(13)  12.4(4)T3
ED Release15.1(1)XB  15.0(1)M2  12.4(24)T3  12.4(11)XJ4  12.4(6)XT2  12.4(6)XE3  12.4(4)XC7
12.4(2)XA2  12.3(14)T7  12.3(11)YZ2  12.3(11)XL1  12.3(8)ZA
MD Release12.4(25c)  12.4(15)T12
You could open a tac case, as even on IPbase this is supposed to work.
Might as well plan an upgrade.
