Attendant Console Setup
Apr 15th, 2010
I downloaded the Attendant Console Plugin. When I click on the icon to launch the program I am prompted with a box to enter the ip address of the call manager which I do. When I click on save I get an error box stating unable to connect to server.The default server port is 2912.
Jaime Valencia Thu, 04/15/2010 - 14:14
  • Cisco Employee,
  • Hall of Fame,
    2011
Make sure the AC services are up and running.
Also check for firewalls/antivirus on your PC and in the network path between the AC client and CUCM server.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Mojo1 Thu, 04/15/2010 - 15:13
I have teh attendant console program loaded and have put in the
CM ip address and my directory number. When you first login  what is my username and the password
Mojo1 Thu, 04/15/2010 - 15:16
Is my Username and Password determined from my End User page? or
from the AC applicattion user page?
