ip communicator to receive a call
Apr 15th, 2010
All,
I have ip communicator installed on my pc. I can make outbound calls without any issues. However, I can not use it to pick inbound calls. Is there a way to do that?
Thanks.
Jaime Valencia Thu, 04/15/2010 - 14:13
  • Cisco Employee,
  • Hall of Fame,
    2011
You'll need to elaborate on exactly what do you mean by that.
Do you not get calls?
1-way audio?
You pickup and calls drop?
Also is this CUCM or CME?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
yuhuiyao Thu, 04/15/2010 - 14:26
Thanks. I put the phone in the wrong partition.
