04-15-2010 02:09 PM - edited 03-04-2019 08:10 AM
I am testing these new ISR G2 routers but now my problem is, on the ISR G2 I don't get the option to set up the protocol to PPPoE under the vpdn group name configuration instead there's only protocol l2tp. Previously I have tested an 877W for PPPoE and it worked well, however, I'm using the same configs and the same ADSL line but I don't get an IP address from my BRAS.
Can anybody post me the basic configs that should be on the BRAS (C10K) and the configs that should be on the 2951 (PPPoE client) for PPPoE connection?
04-15-2010 04:50 PM
You do not need vpdn for pppoe client. The configuration is the same as for any other router, and if doesn-t work, there is something wrong, eg a cached mac.
04-17-2010 12:41 PM
Thanks for your response, however, I need clarity on this issue.
If I'm running PPPoE on an ATM interface, do I need to configure/enable vpdn and if I'm running PPPoA do I also need to confiure/enable vpdn? all these configs are for the client mode.
Is vpdn still needed on the client router if running PPPoE or PPPoA?
04-17-2010 12:52 PM
As indicated above, vpdn is never needed for client.
Documentation that still references that, is obsolete.
04-17-2010 01:52 PM
I dont think so, all you needed was to configure the interface with dialer group. and configure dialer, why dont you show your server and client setting ?
04-22-2010 05:51 AM
