mls qos command
Apr 15th, 2010
If switches do not have the mls qos command what happens to incoming packets that have a DSCP or CoS value configured?  Do they get reset?
Also, if a switch does have mls qos command, but an interface is not set to trust DSCP or CoS, will any marking get reset?
thanks
Jon Marshall Thu, 04/15/2010 - 14:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Luca
Because QOS is quite different between Catalyst platforms the best thing to do is look at the default configuration for each switch to answer your question eg.
3560 -
3560 default configuration
6500 -
6500 default configuration
For others you can get to the configuration docs from the cisco homepage -> Products & Services -> Switches -> switch you are interested in and then select the configuration docs.
Jon
LucaSalvatore_2 Thu, 04/15/2010 - 15:08
Thanks i'll have a read.... This questions is relevent to 3560 switches.
mohamed zafar Fri, 04/16/2010 - 04:38
to enable qos on a switch u must enter mls qos
if the it is cos trust it will remark it will take the trusted value
