RV042 - forward to different port
Apr 15th, 2010
Is it possible to forward complete traffic to, say, 77.88.99.100:1080 to 192.168.1.50:80 in my local network. I can forward port 1080 to 192.168.1.50, but it forwards to port 1080, and I would like to forward to port 80
The ruter is Linksys RV042.
Overall Rating: 5 (1 ratings)
Te-Kai Liu Thu, 04/15/2010 - 19:04
  • Gold, 750 points or more
The Setup>UPnP page allows you to configure such forwarding rule. Note that UPnP does not need to be enabled to use this feature.
dejanristanovic Thu, 04/15/2010 - 19:27
Thank you, but it still does not work. Here is the configuration.
When I go to 192.168.1.50 (from my local network) I have access to my Web camera.
In UPNP section I defined service CAM1 (TCP150->80), added it to the list, enabled it and saved the configuration
In Forwarding section I defined CAM1F service forwarding TCP150 to 192.168.1.50, enabled it and saved the configuration.
Pointing browser to 77.xx.xx.xx:150 (77.xx.etc being my static IP address) does not work. However, when I reconfigure Web camera to use port 150 (which is inconvinient for me because recording software I use insists on port 80) 77.xx.xx.xx:150, which means that UPNP configuration didn't change anything.
Please help.
dejanristanovic Thu, 04/15/2010 - 19:35
It works! I just had to disable port forwarding and use only UPnP. Great. Thanks a lot!
Te-Kai Liu Thu, 04/15/2010 - 19:44
Yes, when there are conflicting rules in Forwarding and UPnP Forwarding, the former rule take precedence. Glad to know you made it work.
