AAA Authentication
Apr 15th, 2010
I Have ASA 5520 In My Network, Here From Inside Users Have To Access The Terminal Server Which Is Located In DMZ. If I Want To Access The Terminal Server From Inside Users It Has To Authenticate By AAA Local Database.
Federico Coto F... Thu, 04/15/2010 - 20:01
  • Green, 3000 points or more
I believe you can do the following:
username user password pass
access-list ACL_AAA permit tcp INSIDE_NETWORK mask host DMZ_SERVER eq 3389
aaa authentication match ACL_AAA inside LOCAL
In this way, when the INSIDE_NETWORK requests to the RD server on the DMZ arrives to the inside interface of the ASA, there's an ACL that's going to match that traffic and also match the aaa authentication for the local database on the ASA.
On the ASA, the command ''sh uauth'' shows if the users are getting authenticated or not.
Federico.
singraj2001 Thu, 04/22/2010 - 02:25
Thanks lot Federico,
I have one more request,
I have the four inside interfaces and one DMZ interface. For each inside interface users have to access the Terminal Server authenticate by AAA using different Username and Password.
thanks once again
S.Rajkumar
Federico Coto F... Thu, 04/22/2010 - 10:19
You can try the following:
Create a local database of users:
username user1 password pass1
username user2 password pass2
username user3 password pass3
username userx password passx
Create an object-group that groups the four inside networks and apply the object-group to the ACL:
access-list ACL_AAA permit tcp object-group INSIDE_NETWORKS mask host DMZ_SERVER eq 3389
Specify the ACL on the AAA rule:
Federico.
singraj2001 Wed, 06/16/2010 - 02:09
When try to configure below comments,
I am facing the error which I discribed below,
ASA does not support interactive authentication for the rules that are applied to traffic other than FTP, HTTP, HTTPS, Telnet and SSH.
