Advertising local host routes in BGP?
Apr 15th, 2010
I have a situation where I'm trying to advertise only 4 host routes from a /24 network to my BGP neighbors.
As an example,
#R1
interface g0/0
ip addr 1.1.1.2 255.255.255.0
standby ip 1.1.1.1
router bgp 1
network 1.1.1.4 mask 255.255.255.255
network 1.1.1.5 mask 255.255.255.255
network 1.1.1.7 mask 255.255.255.255
network 1.1.1.9 mask 255.255.255.255
With a single router, a static route to the interface worked fine..
ip route 1.1.1.4 255.255.255.255 g0/0
ip route 1.1.1.5 255.255.255.255 g0/0
ip route 1.1.1.7 255.255.255.255 g0/0
ip route 1.1.1.9 255.255.255.255 g0/0
When adding a redundant router, things initially work as well..
#R2
interface g0/0
ip addr 1.1.1.3 255.255.255.0
standby ip 1.1.1.1
router bgp 1
The issue arises when R1 fails, R2 has a CEF routing loop..
Troubleshooting Cisco Express Forwarding Routing Loops
Document ID: 26083
http://www.cisco.com/en/US/partner/tech/tk827/tk831/technologies_tech_note09186a00800cdf2e.shtml
The link says the solution is to point the statics to the next hop; which I can't, as they are local.
Is there another way to advertise these host routes?
I've been trying to use inject-maps, but my own routers are the route source, and it doesn't appear to work.
Ideas?
Lei Tian Thu, 04/15/2010 - 21:51
When you say R1 fail, do you mean the chassis is down, or interface down? What problem did you see after R1 fail?
HTH,
Lei Tian
jpazahanick Thu, 04/15/2010 - 21:54
Lei Tian,
Thanks for the reply.
The actual sequence of failure was the SPA card in the router R1, which holds all of the interfaces in question.  So the R1 was unreachable.
The problem we saw was that some of the host routes (but not all of them) were unreachable..  Strange CEF behaviour, but documented in that link from Cisco...
Lei Tian Fri, 04/16/2010 - 15:57
I see, after SPA card fail, you see loop between R1 and R2? How R1, R2 and hosts connect to eachother? Can you post a simple topology for this setup?
HTH,
Lei Tian
jpazahanick Tue, 04/20/2010 - 07:38
upstream peer            upstream peer
  R1 (1.1.1.2)         R2 (1.1.1.2)
   |  g0/0                  |   g0/0
            host (1.1.1.5)
Related Content
