EIGRP thru site-to-site IPSec VPN
Answered Question
Apr 15th, 2010
having trouble getting EIGRP to work through a IOS (2ea. 2811s) site to site IPSec VPN peer connection.  IPSec VPN is working with tunneled static route statements.  Using the basic IPSec policy and VTI interface:
crypto isakmp policy 1
authentication pre-share
group 2
crypto isakmp key "  " address 192.168.x.66
crypto ipsec transform-set vpn esp-3des esp-sha-hmac
crypto ipsec df-bit set
crypto map static-crypt 6 ipsec-isakmp
set peer 192.168.x.66
set transform-set vpn
match address 101
interface tunnel1
ip address 1xx.33.20.226
no ip redirects
ip mtu 1400
ip tcp adjust-mss 1360
qos pre-classify
tunnel source FastEthernet 0/0
tunnel destination 192.168.x.66
crypto map static-crypto
interface FastEthernet 0/0
ip add....
router eigrp 10
passive-interface default
no passive-interface FastEthernet 0/1
no passive-interface Tunnel1
network ....
no auto-summary
ip route Tunnel1
ip route <-- peer's default-gateway is VPN peer router on other side of satelite conection.
must be something simple, but I don't see it.
thanks, kevin
Correct Answer by droeun141 about 6 years 6 months ago
Not familiar with VTI's, but I think you're missing:
tunnel mode ipsec ipv4
tunnel protection ipsec profile
Also don't think you need crypto map on tunnel since it's already on fa0/0.  What does access-list 101 look like? Take a look at this doc:
Overall Rating: 5 (1 ratings)
