Unity 4.0.(5) Public Distribution List
Answered Question
Apr 16th, 2010
Hi Cisco,
We are trying to add a couple of existing subscribers into an existing public distribution list. Under the PDL called "Floor Clients", I goto Members, click on Add Selected Subscribers and when I do a search of the for the subscribers extension number, the result is blank.
The subscriber is setup the same as all the other subscibers already a member of the Floor Client Public Distribution List.
Is there anything I may have missed?
Correct Answer by David Hailey about 7 years 1 month ago
I believe when you are working with DL's, you need to do your lookup based on the subscriber's Display Name...not extension.  Give that a try.
Hailey
Please rate helpful posts!
Overall Rating: 5 (1 ratings)
Correct Answer
David Hailey Fri, 04/16/2010 - 05:27
  • Purple, 4500 points or more
Hailey
