could not issue wr mem command
Apr 16th, 2010
i have 5520 ASA ,i am unable to write config in startup ,means it gives error on issuing wr mem command.
i am able to add or modify the rules
the cpu usage is showing around 30 % while the memory usage is high above 80% as has 512 memory installed
Jennifer Halim Fri, 04/16/2010 - 03:00
  • Cisco Employee,
What is the error message that you are getting?
What do you have in flash? Please share "show flash"
rajsh.sharma Fri, 04/16/2010 - 03:24
now i am able to issue wr mem command but the memory utilisation is still high it is about  at 85 % constant
Kureli Sankar Fri, 04/16/2010 - 03:28
  • Cisco Employee,
When the memory utilization goes high then you can't issue write mem?
We need to figure out what is eating all that memory.  Tracking memory usage is a mundane process. I'd suggest opening a TAC case and letting them collect what they need and let you know if this is a known issue and may be upgrade the code accordingly.
-KS
rajsh.sharma Fri, 04/16/2010 - 03:38
pls find the attached file can you make anything out from that,it
is the output of sho proc mem  .
and i was able to issue the command wr mem when my memory utilisation was 83 %
matt.walls Fri, 04/16/2010 - 03:18
I have seen this before.
try to copy the running config to a new *.cfg file on the disk:0 and then change the config-url location.
arulkumar80 Fri, 04/16/2010 - 03:25
Use running-config startup-config to to save configuration to startup (NVRAM)
Arulkumar
Panos Kampanakis Fri, 04/16/2010 - 15:25
  • Cisco Employee,
You can also try to disable threat-detection and that will free coniguous blocks of memory and you will be able to save it with "wr mem"
I hope it helps.
PK
