Do high tension power line interfere with Wireless
Apr 16th, 2010
Hello Guys
I have a very basic question
There is 66 KV power line going across the land where i want to set up a wirless and RF id based solution. Do this power line
cause any interference for the communication
Harish
Dennis Kline Thu, 04/22/2010 - 11:14
Generally speaking, no... you should not expect any interference.  I have extensive use of  wireless from UHF to 30 GHz microwave near high voltage transmission lines without any problems.  It does raise the noise floor, so the S/N radio of your path needs to be watched, but it's not something I would expect to cause you problems.
