DFM.log grows up to 3 Giga in 3 Weeks
Answered Question
im using cisco works on a windows server system  every 3 or 4 Weeks my backup fails because of  "no disk space".
Searching for the reason i found that DFM.log is too big. After removing  this file the backup runs propperly.
Removing this file needs to stop/start crmdmgtd.
Looking into DFM.log shows many lines of discovery output and i suppose it is the output of a debug command.
in DFM>configuration>logging  logging level configuration is not set.
Month ago i had a problem with DFM and got help from Cisco by an opend Case. i remember that during the work for
this case i was instructed to setup few  commands  like :
dmctl -s DFM put  ICF_TopologgyManager::ICF-TopologgyManager::DebugEnebled TRUE
Maybe i have to reverse  this commands, but not able tu use dmctl commands.
Correct Answer by yjdabear about 7 years 3 months ago
The good news is I don't think TopologyManager is impacted except needing to "Trigger the rediscovery of the device" for the change to take effect, according to the DFM documentation:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_device_fault_manager/3.1/user/guide/dfmfaq.html#wp1014252
So, go to NMSROOT/objects/smarts/bin
Execute the following command "dmctl -s DFM".
From the dmctl command line, enter:
1.
ICF_TopologyManager::ICF-TopologyManager::DebugEnabled FALSE
2.
ICF_TopologyManager::ICF-TopologyManager::LogDiscoveryProgress FALSE
3.
ICF_TopologyManager::ICF-TopologyManager::TraceRule FALSE
4.
5.
6.
Then trigger the rediscovery of the device to stop the growth of DFM.log
Can you elaborate on what you mean by "not able tu use dmctl commands"?
Could you not run the following command to reverse the debugging?
C:\Program Files\CSCOpx\objects\smarts\bin> dmctl -s DFM put ICF_TopologgyManager::ICF-TopologgyManager::DebugEnebled
FALSE
If so, what error messages did you get?
Overall Rating: 5 (2 ratings)
Correct Answer
yjdabear Mon, 04/19/2010 - 08:58
  • Gold, 750 points or more
FALSE
sorry, when i  wrote "i am not able" i wanted to say that i am not familiar with the usage of
the command dmctl. In my last posting i gave only an example of a command.
the full listing of the commands i have done is this:
1.      Enable the Discovery Logs.
Go to NMSROOT/objects/smarts/bin then execute the following command.
       dmctl -s DFM put ICF_TopologyManager::ICF-TopologyManager::DebugEnabled TRUE
       dmctl -s DFM put ICF_TopologyManager::ICF-TopologyManager::LogDiscoveryProgress TRUE
       dmctl -s DFM put ICF_TopologyManager::ICF-TopologyManager::TraceRule TRUE
       dmctl -s DFM1 put ICF_TopologyManager::ICF-TopologyManager::DebugEnabled TRUE
       dmctl -s DFM1 put ICF_TopologyManager::ICF-TopologyManager::LogDiscoveryProgress TRUE
       dmctl -s DFM1 put ICF_TopologyManager::ICF-TopologyManager::TraceRule TRUE
is it possible to set  all to  false  without  stopping the normal work of TopologyManager ?
thank you for your Help
Eberhard
Correct Answer
yjdabear Thu, 04/22/2010 - 10:32
1.
2.
3.
4.
5.
6.
Related Content
