Apr 16th, 2010
hello there what is the use of this IP address?
can anyone tell.. pls
Jennifer Halim Fri, 04/16/2010 - 03:53
It's a loopback ip address. If you need to access some application within your host via ip address, you can use that loopback address.
Example: if you are hosting web on a server, and would like to test the website from the host, you can browse to
Jennifer Halim Fri, 04/16/2010 - 04:09
Yes, absolutely correct. Basically just to check connectivity on the port that you open on your host, and making sure you can access it locally.
harisivaji Fri, 04/16/2010 - 08:44
This IP is used for Internal network loop testing in a node.
to check whether your LAN card is working or not
Saravana Boobathy Sat, 04/17/2010 - 02:37
whether only used  or 127.x.x.x the entire network  are used in that testing purpose ?
Richard Burts Sat, 04/17/2010 - 20:32
The loopback address of is a software construct and does not apply to any physical interface. It helps me when I think of it as an address that a device uses when it wants to talk to itself.
While is frequently used, any of the addresses within can be used for this purpose.
